musikev
Jul 20, 2020Aspirant
Opening ports in ProSafe SRX5308
Hi all, I'm using a program called Livestream Studio for live video productions and have been instructed to open these ports in my Netgear ProSafe SRX5308 Firewall: These ports are: TCP 80 ...
musikev
Aug 03, 2020Aspirant
Confirmed, the port is closed using online port checking tools. And the firewall is the main router.
Thanks,
Kevin
DaneA
Aug 04, 2020NETGEAR Employee Retired
As far as I have checked, there is no issue on the SRX5308 about having port 1935 unable to open. What is the current firmware of the SRX5308? If its not yet the latest version, I suggest you to update it. The latest SRX5308 firmware is v4.3.5-3 and you can download it here.
DaneA
NETGEAR Community Team
- musikevAug 05, 2020Aspirant
DaneA,
I checked, and I do have the latest version of firmware. I'm pretty stumped, particularly because I successfully opened port 20101, but I can't seem to open port 1935 or any other for that matter. Is there an order of operations, or a reboot of the firewall that needs to happen?
Thanks again,
Kevin
