musikev
Jul 20, 2020Aspirant
Opening ports in ProSafe SRX5308
Hi all, I'm using a program called Livestream Studio for live video productions and have been instructed to open these ports in my Netgear ProSafe SRX5308 Firewall: These ports are: TCP 80 ...
DaneA
Aug 06, 2020NETGEAR Employee Retired
Let us try this. Kindly perform a factory reset on the SRX5308 and reconfigure the settings from scratch including Port Forwarding (LAN WAN Inbound Rules). Then, check if the same problem will occur. Make sure that TCP port 1935 (RTMP) and UDP port 2088 are both configured as well on the Livestream Studio.
DaneA
NETGEAR Community Team
