dfilip
Jul 01, 2019Guide
OpenVPN w/BR500 and Static IP
I have OpenVPN working from my Cloud (AWS) server to my local LAN network through a BR500 router:
[AWS Cloud Server] <--> [Public Internet] <--> [BR500] <--> [Local LAN Servers]
Howev...
MrJoshW
Jul 01, 2019NETGEAR Employee Retired
Hello,
You wouldn't be able to reserve an OpenVPN IP address on the BR500, as the setup on the BR500 is client to site with the OpenVPN. DynDNS would not work as well as the DynDNS would resolve to the WANIP. If your AWS setup supports IPSEC you could setup a site to site configuration from AWS to BR500 and the AWS could then access the resources on the LAN.
schumaku
Jul 01, 2019Guru - Experienced User
Check ifconfig-push
„Push virtual IP endpoints for client tunnel, overriding the –ifconfig-pool dynamic allocation.” https://openvpn.net/index.php/open-source/documentation/manuals/65-openvpn-20x-manpage.html
–ifconfig-push local remote-netmaskPush virtual IP endpoints for client tunnel, overriding the –ifconfig-pool dynamic allocation.The parameters local and remote-netmask are set according to the –ifconfig directive which you want to execute on the client machine to configure the remote end of the tunnel. Note that the parameters local and remote-netmask are from the perspective of the client, not the server. They may be DNS names rather than IP addresses, in which case they will be resolved on the server at the time of client connection.
This option must be associated with a specific client instance, which means that it must be specified either in a client instance config file using –client-config-dir or dynamically generated using a –client-connect script.
Remember also to include a –route directive in the main OpenVPN config file which encloses local, so that the kernel will know to route it to the server’s TUN/TAP interface.
OpenVPN’s internal client IP address selection algorithm works as follows:
1 — Use –client-connect script generated file for static IP (first choice).
2 — Use –client-config-dir file for static IP (next choice).
3 — Use –ifconfig-pool allocation for dynamic IP (last choice).
- dfilipJul 01, 2019Guide
Yes, I originally looked at this, but the problems is that it requires me dropping a file into the "CCD" (Client Configuration Directory?) directory of the OpenVPN server that matches the name or remote IP or certificate name of the OpenVPN client. The challenge here is that the BR500 is the OpenVPN server ... and I don't know of any way to drop a client-speciifc file into the BR500's OpenVPN configuration directory???
