Adam1976
Dec 03, 2025Aspirant
PR60X and FunBox 3.0 from Orange in Poland.
I'd like to ask and verify, If my idea will work.
I have a internet in Poland from Orange. It is basen on optical fiber. So a connection is done via a modem called FunBox 3.0.
If I make the connection from a modem using the Ethernet connection - would it work if I connect it to PR60X's WAN port and setup the firewall rules on this PR60X to secure the home network?
The PR60X will than be connected to via LAN ports to GS724TPv3?
1 Reply
Yes, that should work.
Note you would be double-routing, so you'd need to be careful on how you set up port forwarding if you use this configuration.
