PETERGATS
Mar 02, 2014Aspirant
Printing segregated to VLAN by itself
For the life of me, can't get the printer to be alive on its own VLAN.. The SRX5308 is the fw-router (no VPNs just VLANs) Identified 12 VLANs and treating these as port based VLANs and there's a M...
PETERGATS
Default gw of the printer is picked up fine by printer's dhcp, just checked.
When in the default LAN (VLAN 1) it picks up that default gw
Then put it back into port 4 of the M4100, assigned as PVid 40 with its own dhcp range and again the printer booted up fine and when i checked it had picked up the correct ip and the default gw corresponding to the settings of that VLAN, which is VLAN 4 set up on port 4 of the M4100.
Thanx for all the suggestions.
Let me ask all this tho.
Say you want to use just a single networked printer and put it on the dafault LAN (VLAN 1) for all the port based VLAN members to use, VLANs 3 thru 12.
Can i statically assign the printer an ip on the default LAN, give it the correct default gw for that LAN and have all my VLAN members print to it?
Is that a common scenario?
This is what i was trying to do originally.
Can this be done?
Can this be done?
