Coconutdog's avatar
Dec 22, 2014
ProSafe FVG318
I have just bought one of these from eBay. It has firmware v2.1.2-67R. On the Netgear site there is only a link to the Nth American firmware update site. Is there a new firmware for Australia and if so where is it?
Cheers.
  • It may have been a US-only model. It has long been EOL and will never see more updates.
    Cheers.
    Most regional FW created are for modems, so this should work as expected in your location. However, if you are looking for different FW versions for this model, click on "GET MORE DOWNLOADS" , under a search box you will see a drop down for Country, select other (since I did not see Australia on the list) and you should be able to see the FW for all regions.
ProSupport for Business
