Padago
Aug 31, 2023Aspirant
ProSafe VPN Firewall FVS338 - How to configure web access via WAN port?
Hello I have a router connected to the LAN. From the DHCP server, the WAN port gets a local address (192.168.5.11). By connecting to it via any LAN port, I can enter the IP address (192.168.1.1) ...
microchip8
Aug 31, 2023Master
Which router model?
Remote management has been removed from many models due to security concerns.
Padago
- michaelkenwardAug 31, 2023Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:Hardware VPN Firewalls and Business Routers - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
