Padago
Aug 31, 2023Aspirant
ProSafe VPN Firewall FVS338 - How to configure web access via WAN port?
Hello I have a router connected to the LAN. From the DHCP server, the WAN port gets a local address (192.168.5.11). By connecting to it via any LAN port, I can enter the IP address (192.168.1.1) ...
schumaku
Sep 02, 2023Guru - Experienced User
Have configured the Remote Management Access as line-out in the VPN Firewall and Network Management User Manual p.152?
Padago
Sep 04, 2023Aspirant
I have this option set as in the attached picture but I still can't connect. The computer from which I am connecting has the address 192.168.4.11 and the router 192.168.4.24.
Does WAN access require other options to configure?
Regards
- PadagoSep 04, 2023Aspirant
Server 192.168.4.24 is using an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCHIt seems to me that the problem is with the compatibility of SSL protocols. I turned on legacy support in my browser but that didn't help.
- schumakuSep 04, 2023Guru - Experienced User
This is one of the issues you experience if using legacy devices.
A possible workaround using any modern Firefox version is just set security.tls.version.min to 1 in about:config.
Finally it works! Good job! Thank you for your help!
