Padago
Aug 31, 2023Aspirant
ProSafe VPN Firewall FVS338 - How to configure web access via WAN port?
Hello I have a router connected to the LAN. From the DHCP server, the WAN port gets a local address (192.168.5.11). By connecting to it via any LAN port, I can enter the IP address (192.168.1.1) ...
schumaku
Sep 04, 2023Guru - Experienced User
This is one of the issues you experience if using legacy devices.
A possible workaround using any modern Firefox version is just set security.tls.version.min to 1 in about:config.
Padago
Sep 05, 2023Aspirant
Finally it works! Good job! Thank you for your help!
