BobC99
Jul 23, 2017Tutor
qos does not work
Hello I am running latest firmware 4.3.3.6 on my FVS336GV2, and all seems to work well except priority for VoIP calls. I tried to set it up numerous times in the QoS Priority menu item for my VoIP p...
BobC99
Jul 26, 2017Tutor
Yes I tried reseting the unit and it does not help.
JohnC_V
Jul 26, 2017NETGEAR Employee Retired
Please download the configuration file of the firewall and upload it via wikisend so that we can inquire this issue that you were having, if it's okay with you. Please pm me the file ID.
Thank you!
- BobC99Jul 29, 2017Tutor
ok thanks,, I created the .cfg file. How do I add it to this message??
- JohnC_VAug 04, 2017NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance.
- BobC99Aug 04, 2017Tutor
no, it does not work. I have not received any suggestions of how to fix this problem other than reset the unit back to default, which I did and does not work.
