mlsills
Nov 07, 2024Follower
FVS318G
I have an FVS318G that was taken out of service and which I would like to use as both a firewall and VPN in my home network. My Modem is an Altice UBEE connecting to a Google Mesh system. The OS is W...
ReneD
Nov 13, 2024NETGEAR Moderator
Hello mlsills,
And welcome to the NETGEAR Community! 🙂
I understand you are having issues configuring your FVS318G router to work with your network. As per your response, its fine to have the Internet not working yet and you may need to adjust settings on the WAN side. However the router should at least give you a local network since by default the router should provide dhcp on your network upon plugging in a computer. The question is how were you able to configure it accessing its GUI when the local connection is not established yet. I suggest to reset the router first to factory settings and reconfigure the basic settings on wired connection so you can easily established the local network including the Internet. If in any case the router does not build a local connection and will not provide an IP on your network connected via wired through ethernet then there may possibility the router is at fault and needs to be replaced.
https://www.downloads.netgear.com/files/GDC/FVS318G/FVS318G_IG_PRT_20Dec2012.pdf
Have a lovely day,
Rene D
Netgear Team
