Teddi
Dec 01, 2016Aspirant
L2TP vpn UTM10 setting for Apple deivce
I have a PROSECURE UTM10 (firmware: 3.6.2-4) running for years at works and it has a VPN service up and running. But since Apple is not supporting the PPTP/VPN or raw L2TP connection under latest Ma...
DaneA
Dec 04, 2016NETGEAR Employee Retired
Hi Teddi,
I just want to follow-up. Were you able to read and try the suggestions mentioned on the forum link I've provided? Hope it helps.
DaneA
NETGEAR Community Team
Teddi
Dec 18, 2016Aspirant
Thanks DaneA. I am still working toward a solution. I've read through the old forum details, but without luck am still having an error massage from my Apple Device (e.g. iPad iOS 10).
Besically i've already completed the "VPN Policy" Section with "IKE Policies" which i've deicied to use Pre-Shared Key for IPSec/VPN services. In additon to that, under the VPN L2TP Server Section, the Autherication is set to MSCHAPv2. Am sure my Apple devices are working fine with L2TP over IPsec service as i've created another site wtih such service up and running on those apple devices.
Is there any further reference or video, which could show me how to build a L2TP over IPsec service on UTM10? thanks
- DaneADec 28, 2016NETGEAR Employee Retired
I made a research online and only found the following articles below. It is not about L2TP VPN, however you may find it useful in setting up VPN between your iOS device and UTM10.
How to Setup VPN with NETGEAR Firewall and iPhone / iPad
How to Configure UTM and Apple iPhone and iPad for IPSec VPN
Here is another article I found online about setting up ExpressVPN on iOS devices (L2TP):
How to manually setup ExpressVPN on iOS devices (L2TP)
DaneA
