T-Support's avatar
T-Support
SRX5308 Multi-homing working strangely
Hello,   I have an SRX5308 configured to be the gateway for our local network. DHCP is disabled on the Netgear firewall, and is taken care of by a Windows Server 2012 R2 domain controller instead. ...
  • DaneA's avatar
    Oct 27, 2015
    Hi T-Support,
    Welcome to the community! :smileyhappy:
    Would you kindly consider redesigning your existing network?  If yes, then I would recommend using VLANs instead of Multi-homing.  It is because enabling routing between VLANs is possible.  Then, on the IPSec VPN setup, it will be necessary to add a VPN policy for the extra subnet as per this link.
    DaneA
    NETGEAR Community Team
ProSupport for Business
