jxdomb
Jul 11, 2016Aspirant
Remote DNS for IPSec Tunnel Not Correct
I can establish a tunnel using the full VPN client to the FVS318N. Routing into the remote private LAN works as expected. However, DNS does not resolve to any of the names in the private LAN. How ...
- Jul 12, 2016
Hi jxdomb,
Welcome to the community! :)
I am not sure if this will help. However, let me share this forum link I found online.
DaneA
NETGEAR Community Team
JohnRo
Jul 15, 2016NETGEAR Employee Retired
Hi jxdomb,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
jxdomb
Jul 30, 2016Aspirant
The forum link did help me to understand that I needed to manually configure the remote subnet and DNS parameters in the VPN client, or to use a mode config record to have that information be provided by the router during negotiation.
Thank you!
- DaneAJul 31, 2016NETGEAR Employee Retired
Hi jxdomb,
I'm glad that the forum link I found online has helped you. :)
Feel free to post your future concerns here in the community.
Cheers,
DaneA
