JaHall
Nov 06, 2015Follower
Setup Default Static Route on Netgear SRX5308
I am looking to setup a default route to my ISP Consumer Edge switch (We have Metro Ethernet Service with our ISP).
After speaking with my isp I have been instructed to enter a static defualt route of 0.0.0.0/0 to the next hop being our Consumer edge Switch provided by the ISP.
When I attempt to add a static route on the 5308 via Web/Telnet I get the same error. Error is = "destIP IP address AAA.BBB.CCC.DDD where each part is in the range 0..255"
Goal is to be able to add (Destination IP= 0.0.0.0 Subnet= 0.0.0.0 Interface= WAN1 Gateway IP Address= ISP Consumer Edge router Metric=2)
Is there a way to do this successfully on the Netgear?
Thanks
Jarad
1 Reply
- JohnRoNETGEAR Employee Retired
Hello JaHall,
Welcome to the community!
I understand you have some questions with using static route on a SRX5308, let me try to help. You can see an example on how static router is created this following link (see page 131).
If you have questions, the community is happy to help.
Thanks,
