corund
Jun 04, 2013Aspirant
SRX5308 -FVS318G vpn gate to gate connection
hello. I have to devices: SRX5308 and FVS318G. And i want to connect them through VPN gate to gate. Each of them is located in its own LAN: 192.168.0.0 and 192.168.2.0. Also each of them has static WAN IP address. I try to make connection by VPN wizard and connection is established. But problem is that there is no ping between LANs and no any data traffic. Please can anyone give me a link to correct settings to allow traffic between LANs ?
- franck_martin2AspirantI have the same problem but for a Client to Gateway VPN. My problem isn't solved. See my thread.
- corundAspirantIn VPN Policy in Traffic selection section i changed remote start ip address from 192.168.2.0 to 192.168.2.1 and the ping to 192.168.2.1 appeared. Accept this another computer in remote LAN response to ping. But there are 8 computers and only FVS318G (192.168.2.1) and one computer (192.168.2.33) respond. Other 7 not respond. The same situation is in opposite direction. Some computers respond to ping and are accessible but most are not accessible. What may be reason of such behavior?
- jmizoguchiVirtuoso
192.168.0.0/255.255.255.0
192.168.2.0/255.255.255.0
with public IP on both end should work fineBut problem is that there is no ping between LANs and no any data traffic.
Third party firewall on MS Firewall can refuse opposite LAN subnet. You ned to trust, scope of range
