glara
Sep 05, 2016Follower
SRX5308 Cant connect L2TP VPN - Error 709
Hello all, I triying to connect some Windows client to L2TP VPN. I configured the L2TP Server using following guide: http://kb.netgear.com/app/answers/detail/a_id/24393/~/configuring-an-l2tp-vpn...
DaneA
Sep 06, 2016NETGEAR Employee Retired
Hi glara,
Welcome to the community! :)
I'm not sure if this will help. Kindly try to upgrade the firmware of your SRX5308 from v4.3.1-22 to v4.3.4-1. You can download the latest firmware v4.3.4-1 here. Be reminded that it is recommended to perform a factory reset on the SRX5308 after upgrading the firmware then reconfigure it from scratch.
DaneA
NETGEAR Community Team
