JorisN
Mar 21, 2017Initiate
SRX5308 dhcp & login problems
Our company has 6 sites, each with a SRX5308 firewall and VPN connections between them. These firewalls also have dhcp enabled since there is only 1 site that has a windows server, this is our main ...
DaneA
Mar 22, 2017NETGEAR Employee Retired
Hi JorisN,
You may try to downgrade the firmware of the SRX5308 of the main site to v4.3.4-1. Be sure to perform a factory reset after downgrading the firmware then reconfigure it from scratch. Check if same problem occurs.
You can download firmware v4.3.4-1 here.
DaneA
NETGEAR Community Team
