_Mac
Aug 09, 2012Tutor
SRX5308: How config multiple static IPno's?
We're upgrading our firewall from Cisco RV042 to Netgears SRX5308, and we need to do setup the LAN4/DMZ port to handle a RANGE of static IP numbers. xxx.xxx.xxx.10 -> xxx.xxx.xxx.20 We just want...
_Mac
Aug 09, 2012Tutor
We have 16 static IP addresses. One of these are used for NAT, the rest are used for servers (mail, web, dns).
We want to set up LAN1 with NAT for our local network and LAN4 as a DMZ port for our servers. The servers are using static IP addresses from our assigned range and the router should just let them through to the DMZ port. This is the way our old router is configured.
The DMZ setup can only use NAT so that is out of the question.
It seems to be impossible to route one static address to LAN1 via NAT and the rest straight to LAN4/DMZ without conflict. That was at least what I was told by Netgear's support. I was also told that all Netgear routers and fire walls are the same in this regard.
Does anyone know a way around this or do we have to send it back and get a router of another make?
Another thing I found, or rather did not find, was IPV6 support.
Any suggestions?
Any suggestions?
