_Mac
Aug 09, 2012Tutor
SRX5308: How config multiple static IPno's?
We're upgrading our firewall from Cisco RV042 to Netgears SRX5308, and we need to do setup the LAN4/DMZ port to handle a RANGE of static IP numbers. xxx.xxx.xxx.10 -> xxx.xxx.xxx.20 We just want...
OOM-9
Aug 09, 2012NETGEAR Expert
There is an option to run a one-to-one nat where you can set a secondary address to point directly to a private IP address and use an outbound rule to set the private IP address to go out your secondary address.
Did you have a case number for your support case?
