_Mac
Aug 09, 2012Tutor
SRX5308: How config multiple static IPno's?
We're upgrading our firewall from Cisco RV042 to Netgears SRX5308, and we need to do setup the LAN4/DMZ port to handle a RANGE of static IP numbers. xxx.xxx.xxx.10 -> xxx.xxx.xxx.20 We just want...
jmizoguchi
Oct 24, 2012Virtuoso
Let's say that we went ahead and connected the gateway's 4 LAN ports to the SRX5308's 4 WAN ports.
Someone please come back and tell me if this is incorrect. (One reason that I can think of why this MAY be wrong is possibly because the SRX5308 is designed to have 4 different ISP service connections, not 1 ISP connection using all 4 WAN ports - again, I'm not sure about this...
it is worth a trying... theoretically it may work and using protocol binding .
