_Mac
Aug 09, 2012Tutor
SRX5308: How config multiple static IPno's?
We're upgrading our firewall from Cisco RV042 to Netgears SRX5308, and we need to do setup the LAN4/DMZ port to handle a RANGE of static IP numbers. xxx.xxx.xxx.10 -> xxx.xxx.xxx.20 We just want...
adit
Oct 25, 2012Mentor
I remember back when we just had the FVX538 and FVS336G as the only multi-WAN routers. We were specifically told not to connect multiple WAN ports to the same ISP router. It has to do with each WAN port having the same default gateway.
I haven't heard the question come up since then, since the answer was always "don't do it".
If you want to add additional WAN IP addresses for Services in the router, you just create the Inbound Rule and specify the WAN IP address.
