Candide17
Jan 25, 2017Aspirant
SRX5308 inter-VLAN issues
Hello! I have some issues with this routeur since a long time (relay DHCP not usuable, packet dropped, etc...) and each new firmware solve some problems, but not at all... 4 or 5 times by mon...
DaneA
Jan 25, 2017NETGEAR Employee Retired
Hi Candide17,
Welcome to the community! :)
Here are my questions below:
a. How is everything connected? Kindly post a diagram in .jpg or .png format of your detailed network setup.
b. What is the current firmware version of the SRX5308?
c. Is DNS Proxy enabled on the VLANs?
d. Have you tried to uncheck Block TCP Flood and Block UDP Flood as shown below?
DaneA
NETGEAR Community Team
- Candide17Jan 30, 2017Aspirant
Hi DaneA,
My aswers:
a. We have several VLANs managed by the SRX5308, all accross the LAN Port1. Routing inter-vlan is check for each one.
I used relay DHCP but some issues force me to use de DHCP service from the routeur.
b. The current firmware is 4.3.4-2.
c. DNS proxy disable on each VLANs.
d. Nothing is check.
Sorry for lack of detailed network setup. It's on my todo list...
Best regards,
Fabrice.
