goscho
May 01, 2014Aspirant
SRX5308 IPSEC VPN Problems
Hi, yesterday I replaced a FVS336Gv2 (3.x Firmware) with a SRX5308 (4.3.1-22). 2 WANs are configured, WAN2 with static public IP-Adress is used for all VPNs. VPNs are configured to other FVS336, ...
ckleea
Jun 02, 2014Aspirant
goscho wrote: Hi
all problems are now solved.
Issues with LAN-LAN-VPNs wouldn't occur with Beta-Firmware 4.1.3.28, got from Netgear Support.
Client-VPN are working to.
Have to use FQDN as ID for the gateway, not IP-Adress
They gave you the 4.3.1-28 beta firmware. I am using 4.3.1-22 and so far so good.
Would be interested to know what has been updated in the 4.3.1-28 beta firmware?
