TonyArgh
Mar 29, 2018Aspirant
SRX5308 L2TP Passthrough
I have searched. I see this get asked a lot. I did find one thread where someone figured out the problem... but he didn't post the solution. I have reset and updated my SRX5308 with the newest firmw...
DaneA
Apr 03, 2018NETGEAR Employee Retired
Hi TonyArgh,
Welcome to the community! :)
I suggest you try to send a private message to the fellow community member who figured out the problem.
Just for giggles I then tried to use the Prosafe as the server just to see if I could get anything to connect anyway: https://kb.netgear.com/24393/Configuring-an-L2TP-VPN-Tunnel-to-ProSAFE-ProSECURE-routers with a Win10 laptop.
Same error, the generic: The L2TP connection attempt failed because the security layer encountered a processing error during initial negotiations with the remote computer.
Anyone have any ideas what I might be missing?
Let me share the old forum thread below and use it as your reference guide:
DaneA
NETGEAR Community Team
- DaneAApr 10, 2018NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback.
DaneA
- TonyArghMay 10, 2018Aspirant
Months now I've been working on this, a few hours there, a few hours here. MONTHS!
I cannot believe how difficult this is. How this isn't a more common question here just blows my mind.
Finally made a little progress today. Previously I couldn't get the L2TP to work from a Workstation behind the firewall. That tells me it's an issue with the server. Today, I finally found one small setting that now enables me to connect through a workstation on the same LAN and behind the firewall of my L2TP server.
Now if I could just get through this Netgear Firewall.
To recap: We have been using PPTP for 8 years. When we got the new Netgear, it was so easy to set up. Go to SECURITY and add one Inbound Service: PPTP, point it to the internal server: voila. Success.
The link every one keeps sending me to explains how to set the SRX 5308 AS an L2TP server. I don't want that! I just want the router to pass the traffic to the server.
This has to be more common a question?!? It simply has to be ever since Apple stopped supporting PPTP. My users can no longer use an iPhone HotSpot to VPN in. Because I can't figure out how to get the Netgeat to pass that sweet sweet L2TP traffic.
Help?!? This should not be that hard. (Hopefully it isn't).
