TonyArgh
Mar 29, 2018Aspirant
SRX5308 L2TP Passthrough
I have searched. I see this get asked a lot. I did find one thread where someone figured out the problem... but he didn't post the solution. I have reset and updated my SRX5308 with the newest firmw...
DaneA
Apr 03, 2018NETGEAR Employee Retired
Hi TonyArgh,
Welcome to the community! :)
I suggest you try to send a private message to the fellow community member who figured out the problem.
Just for giggles I then tried to use the Prosafe as the server just to see if I could get anything to connect anyway: https://kb.netgear.com/24393/Configuring-an-L2TP-VPN-Tunnel-to-ProSAFE-ProSECURE-routers with a Win10 laptop.
Same error, the generic: The L2TP connection attempt failed because the security layer encountered a processing error during initial negotiations with the remote computer.
Anyone have any ideas what I might be missing?
Let me share the old forum thread below and use it as your reference guide:
DaneA
NETGEAR Community Team
