PSmith
Feb 17, 2015Novice
SRX5308 LAN Port Speed
Is it possible to change LAN port link speed? If so how? Thanks
RX
Feb 17, 2015Luminary
Do you mean to hardcode the link speed to either 1000Mbps or 100Mbps or 10Mbps??? If yes, I believe there is no option for it to change it.
The LAN port will just autosense the link connection. For example, if you want a Gigabit connection to your PC then make sure your PC is capable of it and use CAT5e or CAT6 ethernet cables.
