T-Support
Oct 26, 2015Aspirant
SRX5308 Multi-homing working strangely
Hello, I have an SRX5308 configured to be the gateway for our local network. DHCP is disabled on the Netgear firewall, and is taken care of by a Windows Server 2012 R2 domain controller instead. ...
- Oct 27, 2015
Hi T-Support,
Welcome to the community! :smileyhappy:
Would you kindly consider redesigning your existing network? If yes, then I would recommend using VLANs instead of Multi-homing. It is because enabling routing between VLANs is possible. Then, on the IPSec VPN setup, it will be necessary to add a VPN policy for the extra subnet as per this link.
DaneA
NETGEAR Community Team
DaneA
Oct 28, 2015NETGEAR Employee Retired
Hi T-Support,
For me, the current network setup is kinda not easy to deal with. You may want to consult NETGEAR Support and they might help you with it.
DaneA
T-Support
Nov 03, 2015Aspirant
Thanks for your assistance, Dane.
