DH
Feb 28, 2017Aspirant
SRX5308 need to be replaced?
My SRX5308 is only about 3 months old. The Primary partition holding firmware v4.3.4-2 was working well since purchase. Then yesterday the router stopped doing VPN. Went back to secondary partition w...
JohnRo
Mar 01, 2017NETGEAR Employee Retired
Hello DH,
Welcome to the community!
Did you try refreshing the logs? If so, try dropping the VPN connectivity and then enable it after about 1-2 minutes. See if the logs will show up, if it still doesn't try to refresh it again or reboot the firewall. Have you tested other browsers as well?
Thanks,
