DH
Feb 28, 2017Aspirant
SRX5308 need to be replaced?
My SRX5308 is only about 3 months old. The Primary partition holding firmware v4.3.4-2 was working well since purchase. Then yesterday the router stopped doing VPN. Went back to secondary partition w...
DaneA
Mar 05, 2017NETGEAR Employee Retired
DH,
Just following-up on this. We’d greatly appreciate your feedback.
DaneA
NETGEAR Community Team
DH
Mar 05, 2017Aspirant
Not sure if solved. Logging seems to come and go as it pleases. It will log for a few hours, then no logs for days. These machines must be ancient.
Here is what a log looks like now days. Something happens at reboot with time being not right. If we then go in to pretend to change time setting (without changing a thing but clicking save), it will pick up close to correct time, then a short time later gets correct time, then will start logging and connecting with end nodes (until time is right the end nodes don't play nice with it).
Below is actual log beginning:
Fri Mar 03 14:09:19 2017 (GMT -0600): [SRX5308] [IKE] INFO: Adding ModeCfg configuration with identifier ...
Tue Feb 28 22:42:08 2017 (GMT +0000): [SRX5308] [IKE] INFO: clock skew detected, restarting racoon
Sat Jan 01 00:00:11 2000 (GMT +0000): [SRX5308] [IKE] INFO: IKE started
