nextwavepc
May 10, 2017Guide
srx5308 slow internet speed
we have the latest firmware installed, traffic metering off. is this device capable of handling 150Mb/25Mb internet. we cant get over 55.
DaneA
May 11, 2017NETGEAR Employee Retired
Hi nextwavepc,
The LAN-to-WAN Throughput of the SRX5308 is 924Mbps which is greater than your subscribed speed (150Mb/25Mb) from your internet service provider (ISP) and this should be fine. Let us isolate the problem. Kindly answer the questions below:
a. Was it working fine before even before upgrading the firmware of the SRX5308?
b. If you have just upgraded to the latest firmware which is v4.3.5-3, did you perform a factory reset right after upgrading the firmware of the SRX5308? If not yet, I suggest you to factory reset the SRX5308 then reconfigure it from scratch to start clean using the latest firmware version.
c. Is the SRX5308 set as the main router wherein the WAN IP Address is registered to it?
d. How is everything connected? It would be best if you post a diagram of your detailed network setup.
DaneA
NETGEAR Community Team
DaneA
May 16, 2017NETGEAR Employee Retired
Just following-up on this. Here are my follow-up questions:
a. If you will disconnect the SRX5308 from the modem then connect a PC directly to the modem, are you able to access the internet just fine?
b. Are there any firewall rules configured on the SRX5308? If yes, kindly try to disable all of it and check the internet connection.
DaneA
- nextwavepcMay 16, 2017Guide
Hi there,
yes if we go direct to the modem we receive full speed. and we have no firewall rules in place. We do have vpn to connect to another site.
- DaneAMay 22, 2017NETGEAR Employee Retired
Kindly try the steps below:
1. On the web-GUI of the SRX5308, go to Security > Firewall > Attack Checks.
2. Uncheck the boxes that says "Block TCP flood" and "Block UDP flood."
Note: If both boxes are already uncheck, check both boxes then click Apply. Then, uncheck both boxes and click Apply.
3. Click Apply.
4. Observe the internet connection through the SRX5308.
DaneA
- nextwavepcMay 23, 2017Guide
Thanks,
We tried that and still it is running same. Download of 55
