zarg
Oct 27, 2015Aspirant
SRX5308 tunnel freeze
Hi,
I am using two SRX5308 for few years now with 16 IPV4 IPSEC tunnels each. I am running 4.3.3-6 firmware. For some weeks now, I can see kind of "freeze" of the tunnels. The SRX5308 does not moun...
DaneA
Oct 28, 2015NETGEAR Employee Retired
Hi zarg,
Let us isolate the problem. Kindly answer the questions below:
a. Are both SRX5308 using firmware v4.3.3-6?
b. Was the tunnel working fine before the firmware has been upgraded to v4.3.3-6?
c. Is there an Inbound/Outbound "Any" rule configured in the Firewall rules?
d. Have you asked the ISP on both sites if there are any changes on their ends?
I look forward to your response. Welcome to the community! :smileyhappy:
DaneA
NETGEAR Community Team
- zargOct 28, 2015Aspirant
Hi DaneA,
a) Yes both SRX5308 use 4.4.4-6
b) Yes
c) No rules
d) As far as I know nothing has changed
Since one week now I had only one problem on one of my SRX5308. Weeks before we had to reboot it twice per day...
- DaneAOct 28, 2015NETGEAR Employee Retired
Hi zarg,
So the problem is just on one of the SRX5308. After the firmware was upgraded to v4.3.3-6, did you perform a factory reset on the SRX5308 then reconfigure it from scratch? It is because its recommended to reset the unit to factory default settings after a successful firmware upgrade.
Are both SRX5308 acts as the main router on both sites? The Public WAN IP address should be registered on the firewall itself as this is recommended for VPN. You may perform a continuous ping test via the VPN tunnel on both sites as well then observed.
DaneA
- zargOct 29, 2015Aspirant
Hi,
No I did not perform a factory reset. I will try to do that.
Yes Both SRX5308 are main routers and public WAN are registered. I am using nagios to monitor both public and privates addresses
Thank you
- Jan 17, 2024Retired_Member
