H3llGhost
Oct 08, 2011Aspirant
SRXN3205 Slow file transfer over WLAN
Hello, I configurated my SRXXN3205 with 5 GHz 802.11n (Region: Europe(40Mhz), Mode: 11na, Channel: Auto, Channel Spacing: 40 Mhz). I am using two laptops with full signal strength, but the transfe...
jmizoguchi
Oct 08, 2011Virtuoso
40Mhz is full N using bonded channel so you would expect upto 300Mbps.
each wifi devices will device equally so in nature, speed will change between single wifi <-->wired transfer vs wifi <-->wifi.
3.3Mb/sec is only about 25Mbps
- Jan 21, 2017Retired_Member
