H3llGhost
Oct 08, 2011Aspirant
SRXN3205 Slow file transfer over WLAN
Hello, I configurated my SRXXN3205 with 5 GHz 802.11n (Region: Europe(40Mhz), Mode: 11na, Channel: Auto, Channel Spacing: 40 Mhz). I am using two laptops with full signal strength, but the transfe...
H3llGhost
That is the reason, why I wrote this question and can't understand why the speed is so low. I will test the single devices with a transfer on a wired computer and report the results.
40Mhz is full N using bonded channel so you would expect upto 300Mbps. [...] 3.3Mb/sec is only about 25Mbps
- Jan 21, 2017Retired_Member
