H3llGhost
Oct 08, 2011Aspirant
SRXN3205 Slow file transfer over WLAN
Hello, I configurated my SRXXN3205 with 5 GHz 802.11n (Region: Europe(40Mhz), Mode: 11na, Channel: Auto, Channel Spacing: 40 Mhz). I am using two laptops with full signal strength, but the transfe...
H3llGhost
Oct 11, 2011Aspirant
fordem wrote: You also neglected to specify the source of the data - where was the http server you were downloading from and how does it attach to your network - if it's not on your network, please also let me know the speed of the network connection betwene the networks.
1 Gbit/s fiber.
jmizoguchi wrote: best way to test throughput is this
http://www.ixchariot.com/products/datasheets/qcheck.html
Thanks, I will try :)
- Jan 21, 2017Retired_Member
