H3llGhost
Oct 08, 2011Aspirant
SRXN3205 Slow file transfer over WLAN
Hello, I configurated my SRXXN3205 with 5 GHz 802.11n (Region: Europe(40Mhz), Mode: 11na, Channel: Auto, Channel Spacing: 40 Mhz). I am using two laptops with full signal strength, but the transfe...
H3llGhost
Oct 11, 2011Aspirant
Oh ...
The 1Gb fibre connection is WAN and internal is 10Gb fibre between the core switches and a failover from 1 Gb fibre.
All is connected with 1 Gb Ethernet.
Yes both measures was on the same way.
The SRXN3205 is connected to 100MBits WAN, which delievers 16+ MB/s.
It would be interesting to know, what the SRXN3205 uses.
- Jan 21, 2017Retired_Member
