Noctaire
Jul 15, 2016Aspirant
SSL VPN and IPSEC VPN Setup
Can anyone point me to a guide for setting up IPSEC VPN? SSL VPN - Are separate policies required? What versions of WIndows does it support?
JohnRo
Jul 15, 2016NETGEAR Employee Retired
Hello Noctaire,
Welcome to the community!
Below are some links for setting up SSL and IPSEC VPN:
Configure IPSec VPN Tunnels With the Wizard
Create SSL VPN Portals with the Wizard
Some of your questions are answered on the documents already.
Thanks,
- NoctaireJul 15, 2016Aspirant
Got it; read through those already. Got the IPSEC tunnel up and running with only minor difficulties but still not quite sure about the SSL VPN.
What versions of Windows does the SSL VPN support? I tried testing it on a Windows 10 laptop but that just fizzled (I click the VPN "button" and it just blinks at me).
- JohnRoJul 18, 2016NETGEAR Employee Retired
- JohnRoJul 21, 2016NETGEAR Employee Retired
Hi Noctaire,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
