shieldcomputer
Dec 12, 2017Follower
static IP address does not save, says "argument missing"
Hi, Every time I enter the static ip info I got from my ISP, I click apply and it doesn't save it. At the top of the screen it says "argument missing". I do not see any blank area that I could add...
JohnC_V
Dec 13, 2017NETGEAR Employee Retired
Hi shieldcomputer,
Welcome to our community!
It seems that you were having a problem assigning a WAN IP on your firewall. May you be able to attach some screenshots of the configuration page before hitting apply? So that we can check if there is something that we need to add. You may just blur the IP for security reasons.
