lalek
Dec 01, 2012Aspirant
Static routes in SRX5308 between VLANs.
Hi, I used GS724T switch and SRX5308 firewall for my application. The switch is divided into several VLANs, and one TRUNK port is connected to the SRX5308 port (router on a stick). When I turn on the...
jmizoguchi
Dec 02, 2012Virtuoso
If inter vlan was not enable I don't think you will get any traffice to pass through or VLAN rules
Prosecure UTM series has vlan rules for sure
