atiktepika
Jun 03, 2017Aspirant
VPN CLIENTE LITE LICENCE FOR FVS318N
Dear all, I did purchase a new FVS31N on the fith of June of 2012 and I want to know if I was entitled to a free licence for the lite VPN client. Until now we did use shrew client but this is...
DaneA
Jun 05, 2017NETGEAR Employee Retired
Hi atiktepika,
Kindly click here and fill-up the required fields in order to check if you are qualified to receive free VPN Lite license key.
Let us know the result.
DaneA
NETGEAR Community Team
DaneA
Jun 06, 2017NETGEAR Employee Retired
You may want to try the ProSAFE VPN Client Professional. You may download the latest version 6.40.004 here.
Be reminded that it has a 30-day trial period. After the trial period expires, you will need to purchase a VPN Client license key from authorized NETGEAR Resellers. For the list of authorized NETGEAR Resellers, click here.
DaneA
- DaneAJun 11, 2017NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
