SimoniMilloni
Jan 20, 2023Aspirant
AC2000 WAC124 Access Point Issue
I want to use my AC2000 WAC124 just as an extender from my house to my garden office via the Ethernet cable. So same BT network, same BT password. Instead it keeps on showing the Netgear-1 wirele...
schumaku
Jan 20, 2023Guru - Experienced User
You can change the default SSID from Netgear-1 to whatever SSID you want to be set.
SimoniMilloni
Thanks but it’s not the name - it’s about having one network through my house and office rather than at the moment, i have to disconnect from my house BT network and connect to the NETGEAR network in my office as I move between the two. I just want to extend the BT house network using the NETGEAR router, not create a new network
- schumakuJan 20, 2023Guru - Experienced User
So you configure the same SSID as in place on your BT router, and set the same security mode and passphrase, isn't it?
it's perfectly configurable - just no click and play.
