John_Burg
Jun 18, 2020Initiate
Accesspoint won't join ensemle, but creates a separate one
Hi all, We have multiple WAC720 accesspoints and downstairs we have one ensemble group and for upstairs we want to create a second ensemble group. The group downstairs seems to work flawlessly, ...
- Jun 30, 2020
Hi Raghu,
Thank you for your replies.
The logs didn't show anything useful, so I tried to reset the two AP's that were behaving weird and somehow that worked...
I have no clue why it works now, but I'm glad it did.
So below the steps on how I solved this problem.
1. In the web interface I did a factory reset on both AP's
2. After reset I gave them a name and saved the settings
3. After renaming I added the ensemble group name and also enabled ensemble in one go.
4. Shortly after, I added the ensemble IP address
5 Lastly I enabled the security option
The above steps helped with adding the two problematic AP's.
Thank you again for your help in this.
John
RaghuHR
Jun 29, 2020NETGEAR Expert
John_Burg
Jun 30, 2020Initiate
Hi Raghu,
John
