brandfluke's avatar
brandfluke
Follower
Aug 08, 2024
Best products for a router/modem/access point home network?
Hi all!
I don't know much about this stuff. Forgive my uneducatedness in advance, please.
I'm just a simple guy that wants a reliable and easy-going network. I don't really care about speeds; we really only use our internet for streaming video and surfing the web.
I live in a 3-story townhome and the modem hook-ups are in the basement. We had a ceiling Cat 5 box installed on the top floor for a POE access point. My ideal situation is a cheap and reliable modem/router in the basement, and a POE access point on the upper floor. That should work well enough for our needs.
Problem #1: I've only bought used modems/routers so far and all of them have been crappy. Right now I'm on Google Wifi (barf) and have to reset routers and modems at least once a week when the WiFi cuts out (but ethernet continues to work). What's a simple and cheap router/modem solution? It doesn't need to be able to handle high speeds.
Problem #2: I need a POE access point that works nicely with my router/modem solution. I've tried a Netgear WAX214PA among some other devices in the past, but all of them created new network names/passwords on top of my existing network coming from my modem. I don't want to log into new networks (so to speak) each time I walk up or down the stairs. What's an access point that will make the transition flawless by simply expanding my single home network?
Thank you!
No RepliesBe the first to reply
ProSupport for Business
