matt7277's avatar
Dec 21, 2022
Beware WAX630E Firmware 10.3.1.7 & 10.3.1.8 breaking networks
Heads up that both of the latest firmware updates for WAX630E APs (10.3.1.7 & 10.3.1.8) appear to break my pretty simple set up: Two WAX630E using POE++ Untagged VLAN unchecked  Management VLAN c...
  • matt7277's avatar
    Jan 11, 2023
    Got things working by moving management config back to the default VLAN (1) and split out 2.4ghz, 5ghz and 6ghz to separate SSIDs.
ProSupport for Business
