matt7277
Dec 21, 2022Guide
Beware WAX630E Firmware 10.3.1.7 & 10.3.1.8 breaking networks
Heads up that both of the latest firmware updates for WAX630E APs (10.3.1.7 & 10.3.1.8) appear to break my pretty simple set up: Two WAX630E using POE++ Untagged VLAN unchecked Management VLAN c...
- Jan 11, 2023
Got things working by moving management config back to the default VLAN (1) and split out 2.4ghz, 5ghz and 6ghz to separate SSIDs.
matt7277
Dec 22, 2022Guide
Nice. Are you running the 10.3.1.8 firmware on your WAX6xx devices? If so, have you noticed any issues with operating the management interface on an alternative VLAN ID? Do you have the untagged VLAN box checked?
schumaku
Dec 22, 2022Guru - Experienced User
That makes a different topic I'm following for a longer time here. Unfortunately currently in the local university clinic a stroke center for almost four weeks now, so limited physical access to my test grounds.
