lvchen860217
Mar 17, 2022Guide
Can WAX206 and EAX20 be used together (roam seamlessly)?
Can WAX206 and EAX20 be used together? Wax206 as the main route, EAX20 as the AP, can roam seamlessly?
According to the higher tier of NETGEAR Support, the EAX20 should work with any existing WiFi network. Hence, the EAX20 will work with the WAX206 set to router mode.
DaneA
NETGEAR Community Team
1 Reply
- DaneANETGEAR Employee Retired
DaneA
