TristanDarn
Jan 23, 2021Aspirant
Can't connect to admin page WAC104 Access Point
Hello all. I just bought a brand new AC1200 Dual Radio (WAC104) access point to hookup to the guest room of our house. I was following the setup guide provided in the box, and everything was flowing ...
rswansen
Jan 29, 2021Aspirant
I cannot answer your question, but I am having difficulties re-logging into my WAC104. I set it up a long time ago, and now want to go in and change a setting. I cannot even get the login page to come up. Writing this because, "misery loves company," and I am hoping that the answer to your problem helps me with mine. This is maddening.
DaneA
Feb 04, 2021NETGEAR Employee Retired
Welcome to the community! :)
Kindly try to disconnect the WAC104 from your existing network. Then, follow the steps indicated in the article below:
How do I install my WAC104 access point?
Hope it helps.
DaneA
NETGEAR Community Team
- ianadamsonApr 13, 2021Aspirant
Although the installation steps are correct, this does nto address the infinte password rest loop that occurs trying on the admin page.
I've tried on 6 browsers, 3 operating systems and 4 devices with no luck. This includes, an iPad, iPhone, Macbook Pro and Surface Pro (Windows)- DaneAApr 18, 2021NETGEAR Employee Retired
Just found out from the NETGEAR Support Team that you have an ongoing support ticket. You may post here the progress of it.
DaneA
- 325racerJun 28, 2022Aspirant
Any answer on this? I'm having the exact same issues.
Initial start up brings me to the Admin page where I'm forced to change password. After changing the password I cannot log back into the Admin pages.
