TristanDarn
Jan 23, 2021Aspirant
Can't connect to admin page WAC104 Access Point
Hello all. I just bought a brand new AC1200 Dual Radio (WAC104) access point to hookup to the guest room of our house. I was following the setup guide provided in the box, and everything was flowing ...
bcro
Jan 28, 2023Aspirant
This is what worked for me and has worked every time. On a windows computer google advancedipscanner.com and download it and install, then power up your wac104 and connect it to your router. (I have a comcast router) goto your computer and run advanced ip scanner and click on scan. You will get a list of devices, look for your wac104. If there are more than one verify the mac address. note the ip and open a browser and type in that ip address. you should see the sign in page. If you have problems try resetting the wac104 by using a papper clip to hold in the reset button for no less the 60 seconds. I let it reset for 65 to 70 seconds. then try again. Good luck.
HyperionWS
Jun 21, 2023Aspirant
This worked for me, thx
