Tom_G
Apr 22, 2025Tutor
Can't login to WAC124 any more
Hi, Today, I realized I couldn't log into the WAC124 any more, even though I've been able to do that for the past 3 years. I'm still able to use it as WiFi Internet access point, though. The ...
- Apr 23, 2025
PC (static IP) 192.168.0.123 255.255.255.0 gateway 192.168.0.1 <-> WAC124 (DHCP) 192.168.0.100
-or-
Alternate approach block the WAC124 LAN IP on your router from the Internet access. This won't impact the Wi-Fi / WLAN access to the LAN
Essentially what I explained above already - operate the WAC124 offline!
Apr 22, 2025Guru - Experienced User
the WAC124 is an access point. do you have it connected to a router?
If so, what one?
did you log into the route to see what address it assigned to the WAC?
Use that to try to access it .
