CentralChurchCa
May 10, 2022Follower
Create a VPN
I'm running 3 WAC540s connected to a GSS108EPP behind a Rogers Ignite Gateway. I've been asked to setup a VPN to one of the SSIDs. I've played much with VPNs. Any suggestions?
schumaku
May 27, 2022Guru - Experienced User
A VPN does typically go the local LAN VLAN subnet (where the SSID does point to), and needs to be established from the Internet to a router and the VLAN subnet. Is this what you are behind? Nothing the wireless AP can help here.
